On our current trip we were in Alaska and about to unhitch the 5'er. The wife usually backs the truck up enough to take the pressure off the pin while I pull the locking bar and she drives forward freeing the 5'er from the truck.
When she put the truck into drive the engine just quit. This happened about 5-6 times and then was okay.
I booked the truck into a 5* you-know-what. Here's the diagnosis. 1) I need a new fuel filter because there was water in the filter and 2) I need a reflash of the ECM. I said no thanks to both I can change my own filter and did not want a reflash due to the bad things I've heard on this BB.
I was able to speak with the mechanic and he told me that in Alaska the diesel fuel is poor quality with a lot of water in it. "They use water to push the diesel through". He also said the reflash would cure it. I said I didn't want to risk the reflash and left it at that.
The truck has been okay since.
Anyone run into this condition before.
Thanks,
Richard
Thanks,
Richard
