I just got back my blackstone report and all of the wear numbers are less than average in the report (thanks radix for posting the averages). I sent the oil sample in because I thought that something was coming apart in the engine because of all of the noise the thing makes. The hammering started not long after I went through the latest upgrades that I made which included 370 injectors, increasing timing to 15. 5 degrees, 60 pound valve springs, and governor spring kit. It hammers audibly when on a hard pull and I can hear it real loud at idle if I engage the exhaust brake at idle and listen on the passenger wheel well. Can't hear it at all on top of the engine or on the drivers side wheel well. Anybody have any ideas? Another thing that I just noticed, blow by goes up a bit when I set the exhaust brake.
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer, ATS Exhaust Manifold, Psychotty Air Induction, BD Exhaust Brake
[This message has been edited by dieselburner (edited 01-13-2001). ]
