Details here: TDR Privileges
On a similar note if you install studs, then later need to remove the head, how do you do it? Do the studs screw out easily then you lift off the head? When installed do you run them down tight into the holes in the block or just finger tight? If any get stuck how do you get a grip on them to remove them?
