Did you get ahold of a scanner? Ditto the other comments, I've seen only the 1693 code on the odo, but a scanner found p0236 (MAP hi voltage too long). The other code (the right scanner will also give you a freeze-frame of the ECM/PCM parameters when the code set) will DEFINITELY help troubleshoot the prob. My prob ended up being a loose wire to the inj pump (I also gave it a better ground).
Keep the info coming, I think it helps all of us for possible problems and fixes!
Thanks
