Help! I have a 1999. 5 Dodge diesel, 4x4 quad cab, automatic transmission, Banks Power Pack, Boshe 300HP injectors, Banks Ottomind tuner (disconnected for now).
Recently I had the lift pump, injector pump and injectors changed. Did pretty good for about 1 month. Now I've noticed a pretty significant stumble at idle and when i back out and shift from reverse to drive the engine dies occasionally. Starts right back up though. Also since the work was completed on my truck, I've noticed more oil coming out the breather ... just enough to drip a bit on the driveway. Not sure if these are related etc. . but wanted to give you all the details.
I tried turning the ignition switch to on and resetting the APPS... no change. HELP!!!!
