I decided to take advantage of a warm spring thunder shower and slick roads to have a little fun. I was in the middle of a third gear power brake (5-speed) when I had the brain flash to grab fourth. The TST was on 5:5 so 3rd was no problem but 4th was asking too much. I pulled the motor down and clutched before it died only to find it stumbling, coughing, and blowing smoke.
The stumble was a rough idle that degraded down to about 500 rpm before the computer fueled and it reved up to about 1500 before stumbling down and reving again. I tried turning the TST down to 0 and it made no diffrence. In the mirror (it was dark) I could make out a large quantity of smoke that smelled like when you start a worn out 3406 on a cold morning. Unsure of the color.
I decided to shut it down and look for codes and got none. After that I started it back up and everything was fine. I drove home and all systems normal. Any ideas as to WTF happened here? I feel like such a stupid kid.
-Scott
-Scott
