I have put a 2001 24 valve into a 1998. 5 24 valve 3500 Ram and run into a computer problem. The 2001 24V does not have a crankshaft sensor or tone wheel, therefore the computer is looking for a crankshaft sensor and puts the engine in limp mode. Also the tachometer does not work as it seems to sense off the crank sensor. If anybody has had any experience with this please help and advise, or anyone with enough ECM and PCM knowledge to reprogram the computer. I have both ECM's and PCM's and both engine harnesses, but I am stumped! Appreciate any HELP. Thanks.
