HELP! Engine temp
Today I was pulling a pretty good load with my 2001 3500 5sp, around 16000 I would guess (round bales of hay). I have pulled this load several times before with this truck over the exact same route with no problems. Today, however, I noticed that the engine temp was climbing more than usual, staying up aound 210 to 220 (not quite to the mark between 190 and 240) and would stay there. It was not unusually hot around 90. As I got close to home I thought I could smell something burning and thought it must be the serpentine belt going out (I have 46000 on the truck). Before I could get home the a/c seemed to quit but what happened is that no air will come out of the vents, only the defrost. When I got home, I popped the hood and the belt seems ok, the a/c does blow cold air just from the defrost vent no matter what setting as to position. Odd things I noticed while under the hood, 1) quite a bit of black on the radiator overflow bottle (and it is not as full as it should be) and 2) on the engine behind the turbo is a white powder on top of things. Anyone have any ideas as to what is going on here?
