I do not have access to a shop manual for vavle adjustment and have a few questions:
1. Do I need to be able to turn over the engine by hand to move to the proper position in order to adjust valves? If so, how do you guys do this? With the higher compression of the diesel I think it would be tough!
2. What is the adjustment sequence and where do I read TDC at?
3. What is the gap for intake and exhaust valves?
4. What size allen wrench do you use? and what size nut is used to lock the allen screw in place?
I guess I will need a manual to identify which ones are intake and which are exhaust as well...
Is there anywhere online that has a walk through of how to do this? Cash is a bit tight right now and I cannot afford a manual. Maybe someone could fax / email me copies of the instructions?
Thanks
Phil
