Engine timing pin
TDR chat room
Dodge/cummings/crewcab/info ?
I have a '97 3500 12 valve. When locating TDC how do you push and hold in the timing pin and bar over the motor at the same time since you can't reach them both at the same time. Also after adjusting the valves can you reuse the same valve cover gaskets. Will the seal back up. And do you use any sealer on them. Last, has anyone had a temperature problem like this. My guage cosistently moves up and down from 190deg to 160deg all the time. Antifreeze is ok.
Easy, I don't know the answer to your question, but you really should post this in the 12 Engine and drivetrain section so the guys that do know the answer will be able to help you out. Welcome to the TDR. Good luck.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
