Engine/Transmission (1994 - 1998) engine/trans adapter
2nd Gen Non-Engine/Transmission Speakers
Engine/Transmission (1994 - 1998) Fan Hub Nut Size
Will a NV4500 bolt up to a 47RH engine/trans adapter?? Will the auto starter work with the NV4500??
Thanks,
Chad
Cool!! Ok next question, Can I reuse the bolts I have that bolted the 47RH case to the engine adpater to bolt the NV4500 up to the engine adapter?? I wouldnt see why not. Other question, Can I use the bolts for the 47RH flexplate to bolt the NV4500 flywheel to the crank?? I heard that the manual bolts are longer than the automatic bolts because the flywheel is thicker??? Any ideas??
you will need longer flywheel bolts, but the bellhousing bolts are the same. get the right hydro/slave cyl and your set, plus brake and clutch pedals. just take the knee dash out get the e clip that holds the big rod in and drop the pedals, then put the new ones in. i used pedals out of a 95 in my 98 and worked great. its very easy and cheap to do. just ground the nuetral safty wire and your set. i used my auto cross member and all the mounting bolts, nothing else needed. slid right in place. cutting the hole is the tricky part. get the right boo/console for it and use that for a template.
matt
