GAmes
I just spent a bunch of hours and money fixing oil leaks. i had the IP rebuilt because it was leaking oil and I replaced the oil pan gasket. When I started it up I found the oil pressure sender was dripping, so I replaced it too. I then went on a 1600 mile test drive, 670 of it pulling an 11,000 pound 5er. The engine used a little over 2 quarts of oil. There is no oil in the coolant, BTW. I have read many times that a turbocharged diesel doesn't burn oil, and as you can see I have very little blowby. I'm thinking valve seals, they have about 600k on them. Here is the bottom of the engine and the blowby tube as seen from the rear. No oil anywhere.
