Engine/Transmission (1994 - 1998) Engine Weight
Engine/Transmission (1994 - 1998) vaccumn pump check
I had always heard 9xxlbs. I recently had an engine shipped to me and the bill of lading said 750lbs. This engine had no flywheel, clutch or A/C compressor but was otherwise complete.
I understood the crank is around a 150 lbs. It was said in one of there advertisements or (literature). And high 9's for the hole thing.
_________________________
93. 250 2wd xc 354 auto 268k
04. 5 3500 4wd qc dully 373 6speed 94k
Thanks for the input. I had thought it was in the high 900s. I read somewhere that it was close to 1500 but that didn't sound right.
well depends actually, whether or not u take out the extra cylinders that they messed up and put in the ford lol. 2 to many... . actually i can't say much about the 7. 3 international was and is still a great engine, its predecessors is something to be desired esp. after going to the 6. ? series
Approximate Engine Weight (with standard accessories): Without EGR
Dry Weight for 5. 9 Liters [360 C. I. D. ]... ... ... ... ... ..... 470 kg [1036 lb]
Dry Weight for 6. 7 Liters [409 C. I. D. ]... ... ... ... ... ..... 475 kg [1047 lb]
Approximate Engine Weight (with standard accessories):With EGR
Dry Weight for 5. 9 Liters[/b] [360 C. I. D. ]... ... ... ... ... ..... 519 kg [1144 lb]
Can't vouch for accuracy, but this info comes from the following site that seems to have accurate info.
Cummins CR late model 5. 9 & 6. 7 engine specs/fluid capacities - TheDieselGarage.com
All of the info that I have read states that the 5. 9 cummins got heavier as the generations were added on... that is why there is the descrepincy of the weights of the 12v. the early was in the 975 range and in later years the weight increased.
here are specs for the furd 6. 4
390 cubic inches, 6. 4 liters
Configuration: V-8
Compression Ratio: 16. 7:1
Bore: 3. 86 inches
Stroke: 4. 13 inches
Injection: Direct injection, high pressure common rail injection system
Aspiration: Twin sequential turbochargers
Valvetrain: OHV, 4 valves per cylinder
Oil Capacity: 15 quarts
Weight: approx. 1,150 lbs
Horsepower (peak)*: 350 HP @ 3,000 RPM
Torque (peak)*: 650 lb-ft @ 2,000 RPM
ooh ooh ooh. . found this too...comparison of the 3 Furd "engines"
7. 3 L 6. 0 L 6. 4 L
Weight: 920 lbs 966 lbs 1,150 pounds
Horsepower:* 275 @ 2800 RPM 325 @ 3300 RPM 350 @ 2000 RPM
Torque (lb-ft):* 525 @ 1600 RPM 570 @ 2000 RPM 650 @ 3500 RPM
