Had a strange thing happen today. After travelling for about an hour the engine instantly went to an idle only mode. No response to the pedel at all. I pulled off the road using idle power and found the following codes;
1. PCM. . 1693 (of course) and 0500 (no vehicle speed sensor signal detected during road load condition?).
2. ECM. . 1693 (first time I've got one in the ECM) and 0121 (APPS voltage below minimum)
I cleared the codes with my ScanGauge II after pulling the battery for a few minutes. The CEL went off and all's well. Don't know if this is related but the engines been cold soaking for a few days and temps are in the single digits. The road was wet with snow & slush. i'm wondering if moisture got in the speed sensor (that's in the differential. . right) connector and sent a bad signal to the APPS. That or one of those two sensors is on the way out.
Any ideas?
Mike
ps: truck ran fine for the next 2 hour trip home
Any ideas?
Mike
