Basics: 1998. 5 Dodge 2500 Quad Cab 4x4, Stock Equipment,Except Fuel Pressure Gauge; 206,241 Miles, Original Owner,
5 Speed NV4500 Manual Transmission
Problem: Engine Will Not Crank
Description:
1. Added 10 gallons of biodiesel and after a few starts, engine would require multiple revolutions to start where in the past it had always started with a single touch of the starter.
2. Added injector cleaner/fuel additive with no improvement.
3. Engine began to turnover as if the batteries were weak. Removed batteries and tested. Batteries ok. Cleaned terminals and connectors. No improvement.
4. Engine turned over more slowly and would finally not crank at all. I got a check engine light--P0121--low voltage to the throttle position sensor.
5. Began to check eletrical system. FUSES checked ok both in and out of cab. Relays? No way to check. Grounding cable connection seemed ok.
6. Crawled under truck to look at starter. STARTER was loose. Re-torqued bolts and I thought the problem was solved.
7. Still no cranking. Instrument panel lights will respond. I can hear the fuel heater relay come on and turn off. I DO NOT HEAR THE LIFT PUMP WHIRRING/BUZZING as in the past. No starter click or anyother firewall forward sound.
Please help. I must move a horse before the next weather system arrives in California. I am convinced that it is electrical but I do not know where to look next. Suggestions? Starter? ECM?
Thank you in advance,
Mark Young
Sacramento, California
Description:
Mark Young
