Is the bolt that holds the engine wire harness to the fuse/relay box supposed to tighten so much and then spin? I checked the bolt and It wouldn't tighten much before it spinned. It is the lagge multi pinned plug that has a 10mm head bolt that anchors it.
When I had it in to DC last week, they said that they also performed a wire harness TSB and didn't tell me. I think that the tech(?) stripped out the bolt or nut. Can one of you guys ck your truck and let me know if yours will tighten tight? I'm down to the last 750 miles of my warranty. Chris
