Has anyone tried this scanner on the 24V's. 1999 in particular?
For $120 it seems like a decent deal. No computer or software to mess with. Kragen even has a special for $129 right now.
http://216.65.58.60/Merchant2/merch...e=FAPWAP&Product_Code=3100&Category_Code=CODE
It is not fancy and will not reprogram things. I am mainly concerned about checking for codes which would not set the check engine light as I have my EZ on. I am a bit confused as to the ECM/PCM interface and how it relates but I am learning. I am assuming that the codes which do not set the check engine light are in the ECM and the PCM does not know about them therefore no check engine light?
Thanks,
Thanks,
