01-2500. Have problem with very erractic operation,rpm's will fluctuate, missing,smoking, unplugged edgeez, helped for appox 200mi. and same problem is back. Changed fuel filter, no help, please help.
ajphillips said:do not have code reader, but soon. Fuel pressure is 16psi at pump could this cause a problem? Also I have very low boost pressure, got truck home, so emer. is over. Went thru procedure for resetting APPS, the truck did start but very, low boost, will check tomorrow. I did not mention but the . 22 cal trick has been done on this truck, I will remove. Could manifold pressure sensor cause low boost? Thanks for replying.
ESorensen said:What is the . 22 cal trick?
