Engine/Transmission (1998.5 - 2002) Erratic fuel pressure
Engine/Transmission (1998.5 - 2002) cwversyp
:confused:
I'm running a FASS Platinum fuel system with the engine filter still in the system. The pressure gage is connected between the engine filter and the VP44.
usually the pressure is 12-16 PSI while running. Sometimes it goes to 18-20 and I have seen 28.
Which relief valve could cause this, the one on the VP$$ or on the FASS pump?
It could also be your fuel gauge giving u eronious readings. The pulses tend to ruin electric gauges even the snubbers will wear out over time.
Pressure between 12 and 17 PSI is not a problem. Low pressures have, in the past, been form dirty fuel filters. It is the HIGH pressures that I worry about. what causes them and what will they do to the VP44?
