I know I'm beating a dead horse here, but here goes. Last month I installed a Westach fuel pressure gauge using the fitting at the bottom of the fuel filter housing using about 2. 5 feet of fuel hose to isolate the sending unit. At first everything was rosy, good steady pressure around 14 psi at idle and didn't drop below 7 psi WOT. In the last few days the readings have gotten erratic and I'm not sure if my lift pump is on it's way out or if my fuel pressure gauge set up may have a bad sending unit. By erratic I mean 10 psi then go down to about 3 psi while driving and about 1 psi WOT. I shut the truck off and restart and it goes up to about 13 psi then drops down to 10 psi at idle and then downhill from there. Has anyone experienced anything like this? Not sure if it's the lift pump or sending unit. What do ya think?
2001 QC ETH 4x4 25,000 miles
