I recently went through (resealed and cleaned up internals) my 114 pump off my 90, changed DV holders and put it on my 92 to run while I decide what to do with my good (205) pump and where to get it rebuilt. Lately it has taken to idling just fine if I put the transmission in neutral and coast up to the light, but about 5seconds after a complete stop, the idle drops considerably- like "be careful starting in 1st, I may kill it" RPM drop. A/C does not afect it. I did notice some slack overall in the pump before and after the "rebuild", but thought nothing of it at the time. I did have it calibrated at the local shop and set to 90cc/ 1600 pump RPM.
So, even though I suspect it to be the pump, what else should I check besides the usual- fuel pressure, leaks, etc? Timing is at or near stock, but not behind, but this is a fairly recent development, too. Timing shouldnt be a factor. I know, swap pumps and see what happens, but I'd like to get my 205 ou & rebuilt, and get it back before the drive to IN next month.
Daniel
Daniel
