Engine/Transmission (1998.5 - 2002) Error codes set by the MAP Sensor?
Engine/Transmission (1994 - 1998) proper coolant ?
Could a P - 0216 (injection pump timing failure) code be set, or directly related to a faulty MAP sensor?
If so, wouldn't there be a slew of other codes being set also with a bad sensor, or could it be "Kind of bad" and just set the one?
I am trying to eliminate all the possibilities before I have to go to the dealer about a VP that may be taking a header.
