ETH + EZ + DD3 == Yeeehaaa!!
Problem with Boost Module
Front brake rotors
Many thanks to those today who helped me install my DD3 injectors, specifically Colin Cahill.
The initial drive after installation was promising, but didn't tell the whole story. It wasn't until I got on the freeway for the trip home, that I realized just how powerful those things are!
I immediately ended up in a little "race" with three kids in a Honda Civic who decided to cut off the "slow" truck. They didn't lose me, and in fact, I blew past them at 90+ mph.
My EGTs saw a max of 1359 at 98 mph (my GPS said that's as fast as I went), so I don't consider that bad at all, since I still have the stock turbo.
Temps are definitely higher than before, but I don't think it's any worse than my '96 was with the TST #5 plate and 16cm2 housing, 230 hp injectors, stock exhaust, and K&N filter.
Awesome combo... smoke is minimal too. This truck is finally as strong as, or stronger than, my 96 (I'm guessing stronger by 25-50 hp).
Now to see how long my clutch lasts... #ad
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate, 4. 10, USGear OD, Rickson 19. 5 Wheels, DD EZ, DD3 Injectors, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc.
Good for you Rob..... When you came back from your test drive, you didn't have the big grin I was expecting..... #ad
:, I know for me it took a coupl'a days to get the true feeling of the bigger injectors, and it sounded like you had some fun on the way home... . Next?
Colin
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
hey rob , glad to see you post a positive experience with your RAM , you seemed to be down on it as of late . yes DD3's are awesome , even by themselves . #ad
