My 89 WILL NOT START unless I use ether and I can't figure out why. Less than a half a second with aerosol ether is all it takes to get it started. Idles fine and drives fine as long as it is under accelleration, if I let off accellerator for a light or stop sign it MAY go dead, not always. If it does, ether is the only way to get it started. Engine temp can be 180 and it won't start without ether. I changed out the lift pump, changed fuel filter, replaced supply and return fuel lines, what else can I do? Any info will be greatly appreciated.
