Engine/Transmission (1994 - 1998) ever lose a oil pump???????
Engine/Transmission (1994 - 1998) Banjo bolt size
2nd Gen Non-Engine/Transmission 41,800 miles on my front brakes.
Have a buddy with a 96 that lost a turbo. . replaced that and discovered no oil pressure. He pulled the turbo oil line and had no oil flow and the filter was partially empty. seems to run fine..... but??? could a KDP failure cause loss of oil pump?????? HELP
well found a piece of aluminum "slag"?? in the impeller its a piece of aluminum about 1/8 inch dia about 1/4 inch long, semi rectangular with a round end. the inlet screen is 100% intack and not clogged???? this is a stumper???
