Tonight I pulled all six of my injectors to install some other ones. I was surprised that half of the mounting bolts that hold the injector to the head were just finger tight. I put a socket on it and felt no resistance. Very strange. Ever hear of them vibrating loose? All of the loose ones are the rear bolt. I'm wondering if they torqued the rear one and then torqued the front one? Then never rechecked the front one.
Then the fuel line that connects number five was finger tight and appears to have been leaking for some time.
It took me just two hours to get all the stuff unhooked and six injectors pulled. That included intake, batteries, valve cover, valve cover gasket,all the lines plus injectors! Install will be slower as I do all the torque specs and procedures to make it right.
I studied the injector removal procedures on our great TDR Website to have a plan! Thank You! I knew wrench sizes too before getting started! PERFECT!
I'm adding a new inline fuel filter once I get my truck running again. I decided do one project at a time in case sometime isn't right when restarted.
Any loose bolts found before? Thanks, Herb
