EVS-II won't disarm with all 4 locks unlocking
Trailer light relay???
Radiator Problem
I have found that my EVS-II alarm works fine when I have the key fob set to unlock only the driver door when used. It works fine if I have the horn set to beep or not to beep when using the key fob to lock the vehicle.
The problem is that when I set the truck up to unlock all 4 doors with the key fob, the alarm WILL NOT disarm. :confused:
Weird? I think so. I might consider having the dealer look at it again. They are the ones that installed it. It might be a while since it is not that big a thing to me. It is more of a puzzling thing I want to understand.
Mark H
That is weird. I have mine set up to unlock all 4 doors with one push and my EVS-II disarms OK. Mine is an '03, so maybe there is a difference with your '06 FOB. You have the FOB built into the ignition key, correct?
