Engine/Transmission (1998.5 - 2002) Excellent Alignment Article
HEMI®Dart
I found this at Fritz's Web Page: I did not write this. #ad
In a previous posting written by ???? (don't remember), they were complaining about a shimmy in their Ram 4x4 after striking bumps in the road.
I suggested that the front end alignment has either too little or too much caster, thus causing a caster shimmy. He did not like my response and changed his concern from a "shimmy" to a "bounce" (big difference), and insisted it was the shocks. Maybe it is, I haven't driven it. He also said the alignment "checked out". Here's the problem:
Alignment programs (and service manuals I believe), give a wide acceptable range for front caster on the 4x4 Rams. I believe the range is 2 degrees to 5 degrees (if that's not correct, it's pretty close). The problem occurs when the alignment tech (independent or dealer) tells you that the measurements "checked out fine", just because they were in this broad range of acceptance.
Caster readings that fall on either end of the scale are subject to caster shimmy, even though they are "acceptable". I had to align some 30 trucks and attend a 9 hour "Dodge Ram Chassis Dynamics Diagnostics" training session (fancy name, ehh?), before finding out that 3 degrees to 4 degrees is the optimal caster setting for 4x4 Rams that eliminates caster shimmy.
Below I will post what specifications I set Ram trucks to. First I want to give a little more info on correct Ram alignments so you can see if you had a job well done,
The eccentrics on the lower control arms ARE NOT for individual wheel caster adjustments (even though our alignment machine says they are). The eccentric sleeves in the upper ball joints are for adjusting individual camber and total cross caster (difference in caster between two front wheels). This is why replacement eccentrics are positionable in eight different ways.
Once camber and cross caster are attained with the eccentrics, the lower control arm eccentrics are then used to swing the caster readings into specifications. The two eccentrics must be swung in the SAME direction in EQUAL amounts. If they are not, it will create a setback condition (one front wheel further forward than the other).
FYI - Comparing between the two front wheels, caster will cause a pull to the smaller value and camber will cause a pull to the larger value. A truck set up with caster pulling in one direction and camber pulling in the other direction, can lead to a wandering truck; even though it is "in specifications"!!!!!!
If the eccentrics on the lower control arms of your truck are not pointing the same direction, the alignment was done incorrectly and the axle was "twisted" or "forced" into position to attain the acceptable values (seen them from the factory this way, go figure).
A correct alignment will set the truck up with a slight negative cross caster (truck has slight pull to left) to compensate for right hand road crown. Camber will be equal side to side slightly on the negative side. This will help maintain acceptable camber when hauling heavy loads, as the truck tends to lift in the front when towing. Camber will then fall slightly positive when towing.
Just because the alignment shop says "it's in specifications", that does not mean it is set up for proper performance and handling!!!!!!!!!
Specifications (my personal settings for every Ram I align): all specs below are in degrees.
Left Wheel Right Wheel
Caster 3. 2 3. 5
Cross Caster -. 3
Camber -. 10 -. 10
Cross Camber 0. 0
Toe - standard specs, (maybe a little out if you tow a lot, they will pull in as the front end lifts up).
Brent
ASE Certified
Gold Certified Chrysler tech
[This message has been edited by HEMI®Dart (edited 03-01-2001). ]
That is a good article
thoes are the specs I had my truck set to at a 4x4 shop after the gear box replacement ( 3" play in wheel from factory ). then it pulled slightly to right. Dodge had the lower ecentrics in oposite directions causing the pull.
It was in fact specs just not aligned properly to get it into specs. It drives like my 97 PSD did, straight and true. that post was the greatist thing for my truck as far as driving pleasure. Been over 10k on the alignment and tires are not cupping and having to be rotated every 5k miles. Makes towing almost a pleasure.
[This message has been edited by JNutter (edited 12-15-2000). ]
Anyone know Brent's Location, I would for him or his shop to perform an alignment on my 2001 Dodge??? City , State, Phone # would help! This article is Great!
Great article Brent,the only time i make changes from the specs you posted are,if the vehicle is an OTR pulling truck,Ill set the cross camber at 0 and caster at 4 degrees,since more caster = better high speed stabilty(to a point). Plow trucks,and local trucks get a little less caster and slightly more positve camber,as they have a lot more weight on the front axle. The biggets complaint is loose sterring,which seems to be normal on these,almost all the ones ones I work on have worn track bar and exceessive steering box play. Customers are amazed at how much better the truck tracks when everything is tight and alignment is at ideal specifications.
This write up has been around for a few months. Not sure how it got on Fritzs' site, but I originally posted this on the TDR. I found this in the alt. autos. dodge. trucks newsgroup. Brent posted this in the newsgroup on 02/10/2000.
Shelby
2001. 5 2500 QC LB 4WD, ETH, DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Built 09-15-00, took delivery on 10-06-00, 1749 miles as of 11-25-00. Custom aluminum work body / flat bed. Coming soon: E-Brake and gauges.
This is the kind of info that makes the yearly dues worth every penny #ad
Time to get out my factory service manual an learn how to read the alignment specs and check them against the article. Next is to find a shop that doesn't give me a funny look when I come in and say I want my truck aligned to these specs exactly. I'm gonna add the Skyjacker 2" lift in front and have been worried about screwing up the alignment which from the factory has been perfect. Great work guys, Thanks! #ad
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
My truck does not have any shimmy or shake, but what i am wondering, is has anyone tried these specs to cure the right pull. It seems that as the miles add-up that it pulls to the right more. I have about 43,000 miles now.
Rattlin' Randy J 1999 Quad-Cab, 2500, 5-Speed, 4x4, Short-Bed, Rhinolined,
Limited Slip, Tow Package, Camper Special,K&N filter, staight exhaust with 5 inch
chrome tip,diamond tread alu. tool box,Also 1971 Convertible Barracuda Tored
340 4-Speed
Guess you did not read my post
Dawg,
I do not know where Brent is located. I have exchanged e-mail with him, and I am encouraging him to become a regular part of the TDR. He promised to check it out, and may be joining after the 1st of the year. He at this time is willing to correspond with e-mail as time allows, but wishes to remain somewhat anonymous both for his sake and his employer's sake. Anybody wanting to e-mail him, please send me an e-mail, and I will forward his address.
Shelby
Originally posted by HEMI®Dart:
Here is the link to Alt auto where I found the article. This is where it originated. http://x52. deja.com/%5BST_rn=ps%5D/getdoc. xp?AN=584018553&CONTEXT=963611422. 3487 82594&hitnum=5
Hemi,
That is it alright, but Brent is not at that e-mail address any longer.
Shelby
This article poped up a few months ago.
It is my understanding that it will not work on 2000 and newer trucks. The great engineers changed the ball joint design, no excentric bushings!!
Am I wrong in this understanding?
2001 WHITE 2500 QC, LB, 3:54, 4x4, ETC/5-SPEED, HD TRANSFER, FACTORY FOG'S, MOPAR MUDFLAPS, AUTOMETER ULTRA-LITE PYRO & BOOST, BOSCH 275'S, K&N IN STOCK BOX, SILENCER RING AOL, JARDINE 4" IRRIGATION PIPE, BFG 285/75/16 ALL TA'S ON EAGLE SERIES 58, ICS NERFS, ARMA TUFF SPRAYED BED, LOOKING FOR AN EZ FIX. 16000 MILE SINCE JUNE ****POLARIS 700 RMK RULES THE HILLS****
mine still has a pull to the right. I'm going to see my dodge dealer this thursday for an alignment (again). Will this fix my pull to the right and will it work on my '01 4x4.
Thanks!
Frank
01 White, Quad Cab,Short Box ,Sport SLT+,5 speed,4X4,line-x ,Nerf bars,fiberglass tonneau cover
Surveyor Shelby
It's probably good Brent has a different E-Mail address now. I'm sure he wouldn't want 5000 messages in his mail box with questions about alignment. #ad
[This message has been edited by HEMI®Dart (edited 03-18-2001). ]
Brought this to the top as its getting old enuff to be "lost" (90 day cut). A friend needs this for his 4x4 problem.
SOTSU!!
\\BF//
[This message has been edited by Ben Stair (edited 03-18-2001). ]
Mine drifts to the left. And this is after offset ball joints on the drivers side to correct camber and SS's bracket and 3rd gen track bar. Dodge says its "right on" and I'll have to live with it! Thinking I'll go to another independent shop and have it checked out again - and bring the article along. Any other suggestions would be appreciated.
Hobart,
You got to find a good local guy that knows Dodge trucks. It's ain't easy. It took me maybe 6+ tries. Found an older guy at a Medium/Heavy truck shop that dials it nice. I can almost take my hands off the wheel on the highway and it tracks as straight as an arrow.
