Excessive fuel in oil
My opinion on new AFE Torque Tube install.
Update on manual fan clutch switch
Two months ago my dealer replaced two injectors because of a skip on start up and oil level about 3/4" over full. Three thousand miles later my oil level is creeping back up but w/ no skip. I haven't had a oil analysis done but I assume it is diesel bringing the oil level up. What kind of tests can they do to diagnose this? I know warranty will take care of it now but I dread what will happen when the warranty is gone.
If it were me, I would get an oil analysis done ASAP and go from there. It could be something else making the oil creep up, namely coolant comes to mind.
Once you have an oil analysis done you can take the results to your servicing dealer and have them fix whatever the issue is.
