Have a 2001 ram just had the injection pump and lift pump replaced. And it now cranks extra long when starting. At least 3 to 4 cranks then starts and it runs smooth when it does start. Does not happen all the time . thought it was from ladent heat on the injection pump after running but it will sometime happen when cold also. Doesn't start like it use to when old injection pump was on it. Which was instantaneously. Need help only has 85000 miles.
Also have a real slow leak on ac system, have replaced low pressure switch , O rings,and the evap 2x and it still leaks down takes about month of not running. The dealer has put dye in it and used a machine to check for leaks and can't find it. I was thinking the Schrader valves might be it now. Been dealing with this for over year. Thank god it hasn't cost me since the original repair. But am loosing my patience!!!!!
