The other day I noticed that around 50+ MPH the truck started to have excesive vibration when on the gas pedal. When I would let off the gas pedal vibration seems to go away. Listed below are possible options in the maintanance manual. Any ideas on where would be the best place to start or anyone have any other ideas? Also at 50+ mph the exhaust has a different sound as well. This also just started the other day when things started to vabrate. It sounds like something could be plugged up. Exhaust now sounds muffled and lower than usual. Anyone have any ideas??#@$%!
1. Loose or broken engine mounts.
2. Damaged fan or improperly
operating accessories.
3. Improperly operating vibration
damper
4. Improperly operating viscous fan
drive.
5. Worn or damaged generator
bearing.
6. Flywheel housing misaligned. 6. Check/correct flywheel alignment.
7. Loose or broken power
component.
8. Worn or unbalanced driveline
components.
damper
drive.
bearing.
component.
components.
