In recent weeks I've noticed several new threads by new people asking about twins. The info is concentrated on the turbos, what works good together. I have read very little about sizing the exh system for your power level. One post by someone that I feel has a solid knowledge background in this area says that "up to 570 HP a 4" system is ok". Another person wrote that "after 500 HP you need a 5" system. I know several of you guys have had twins for a long time and may have changed exh systems and noted improvements and/or no changes. Would you guys share your exp with the rest as to what is needed and what worked for you. FYI, I run a 4" dp then 5" straight pipe, no muffler, although loud and annoying on long drives, it sounds great ripping through the gears. My B2 is on order awaiting it's place below my 40.
Al
Al
