2nd Gen Non-Engine/Transmission Exhaust bolts
Engine/Transmission (1994 - 1998) Painting Head: best stuff to use?
HELP! I bought the DPP 4" exhaust kit -- but I can not get my old system off! The bolts where the turbo ends and the exhaust begins (connected with the flange) just won't budge!
I used my BIG pneumatic wrench and I couldn't get to the bolts. I used my SMALL pneumatic wrench and it wasn't powerful enough to knock them loose.
Any suggestions????
Thanks!
Matt
Have you soaked them with penetrating oil? Them there bolts have had a hot life, try soaking them for a couple days and then try again. I used a few extensions and got the bolts from the bottom.
Try a BIG breaker bar, with a couple of extensions from the bottom. You should be able to do one of two things, break it loose or snap it off.
Mine had 140k+ on them when i did my 4'' exhaust, the shoulders had gotten so thin that i knew they would snap as soon as i put a wrench on them. I soaked them with blaster then heated the turbo flange threads with a torch too almost red hot and they started to move. I had to work them back and forth as they would tighten up, also kept spraying them at the same time. The threads were undamaged when done. When i started i just knew i was going to pull the turbo before this job was finished, it has'nt been off as of yet. New bolts from the dealer are only a couple bucks a piece. High-temp never-seeze is the best thing for this area, go slow and take your time and they should come out.
Hey Guys!
As you suggested, I soaked the bolts with PB Blaster for three days while the engine was warm. With a couple of extensions, I was able to get to the bolts from the bottom and they came right out.
I then had to hack saw the old system in half so I could get it out (it just wouldn't make the turn with the skid plate in the way).
Once I got the old system out, the new one installed in about 30 minutes. It lines up PERFECT with the factory mounts. I was very impressed. I love the sound as well. Really not much louder than factory.
Does anyone happen to know the specs of the bolts that connect the exhaust up to the turbo? I got a little carried away with the wrench and rounded off the head of the bolt just prior to getting it 100% snug. Ruined an otherwise perfect install.
Thanks again for the advice!
Matt
