H Barlow
Regarding "Reverse Thrust Bearings"---I have a 2003 5. 9 HO with 48RE--155,000 miles---am considering the BD Eqipment Exhaust Brake with Pressure-Loc to maintain TorqConv pressures--Would the "thrust bearings" still be considered a potential problem in this situation?--Appreciate your comments--Thanks in advance--
JDennis
JDennis,
I've been out RVing for a few days and missed your post.
I don't know anything about BD products or the claims they make but I can tell you this:
At the TDR Rally held at the Cummins Mid-Range Engine Plant at Columbus, IN in summer of 2002 just weeks before the new HPCR engine and Gen III trucks were introduced we attended lots of briefings with Dodge, Cummins, and Jacobs engineers to discuss the new trucks. Carlton Bale, a Jacobs Exhaust Brake engineer, told us that Dodge and Cummins planned to offer new trucks with automatic transmissions and factory approved exhaust brakes very soon.
As it turned out extensive testing first determined that the 2003 and 2004 truck ECM's lacked adequate computer size to contain all the necessary programming to integrate the engine, automatic transmission, and exhaust brake. When that limitation was overcome it was determined by extensive testing that the 48RE automatic contained a reverse thrust washer that would fail early under continual use of an exhaust brake.
One or more long-running threads here in the TDR website recorded the discussion that was updated occasionally by Carlton Bale, the Cummins/Jacobs engineer. I'm sure the thread is archived.
Finally, following upgrades to the 48RE, for MY 2006 Dodge/Cummins/Jacobs agreed that a 2006 Ram could be ordered from the factory with a dealer installed Jacobs Exhaust Brake sitting in the back floor. Neither Cummins or Dodge installed the exhaust brake on the assembly line but it appeared on the order sheet, dealer invoice, and MSRP. The eb was shipped in the original box resting on the floor behind the driver's seat. I ordered one of the early ones and it worked great for 230,000 miles.
You can draw your own conclusions as to whether your 47RE or 48RE will hold up to continued use of an exhaust brake while towing. My guess is BD will tell you it will. Unless BD also upgrades the transmission internals to handle the reverse thrust the limitation found by Cummins/Jacobs still remains. One of the excellent 48RE rebuilders often mentioned here on TDR could upgrade the transmission to handle the exhaust brake.
