There is a reason why Dodge says do not install exhaust brakes on rigs with automatic transmissions. The exhaust brake cooks the transmission if you don't have a switch to lock up the torque converter. The exhaust brake will turn the engine down to an idle and hold it against the torque converter. With this condition you are operating closer to a stall condition and generating much more heat in the torque converter, not in the engine as a manual transmission does. Also, an automatic transmission sends oil to the cooler after all other needs are met. This means virtually no cooler flow with an input shaft rpm below 1500 rpm. In town you would have much operation below 1500 rpm. The manual torque converter lock switch is used by people on long downgrades pulling a heavy trailer. The locked up torque converter will cause the truck to buck and kill the engine if you try to stop without manually switching it off. An automatic transmission does not automatically shift from low to neutral when you come to a stop. If you install the manual switch and use the exhaust brake in heavy stop and go traffic, you will be as busy as the one legged man in an ass kicking contest (or was that the one armed paper hanger).
'97 SLT 2500, Cummins 4x2 LB Club Cab, auto, 3. 54 LSD, white/driftwood, air dam, sliding rear window, towing/camper pkgs, Rhino liner, stainless bed caps, stake pocket tie downs, chrome exhaust turn down, stainless wheel well trim, Carr steps, Cobra 25W CB/Firestik, J-MAC louvered aluminum headache rack and fifth wheel tail gate, Reese 15k fifth wheel hitch, 29 ft Dreamer fifth wheel, fully loaded GCW=18,000 lbs. Kennewick, Washington.
[This message has been edited by Boldt's Wagon (edited 12-18-1999). ]
