Most aftermarket Ebrakes have a black box control for the auto. It includes the pressure lock, this is a vauum controlled valve that increases line pressure when brake is active. On the Banks, and most others, when the truck is started it turns on the EB to aid warmup. Touching the accelerator disengages during warmup and when stopped it turns it back on until temp gets to about 140. Acts like the heat riser in gasers. When the brake is being used the TC is locked until speed reduces to 22 mph with OD on and 18 w/OD off.
The black box connects to ECM wiring. TPS, ECT, VSS and OD switches are connected.
The pressure lock mounts on the trans on the drivers side. The throttle cable is removed and the unit mounted, then the cable is reconnected. the 47re has very low line pressure at idle and increases with throttle movement. The pressure lock forces the pressure to full on during operation of the EB.
The only thing is if you use the truck brakes to stop quickly the unlock process and the down shift happen at almost the same time. This can be felt as the trans can't react fast enough to unlock and shift at the same time. This happens during panic stops and hasen't hurt anything yet.
I run the EB all the time. It's nice coming to a freeway offramp and having the truck slow when off the gas. Really saves the trucks brakes. Since braking is not very effective below 2k rpm in town it's not as effective.
