Tom,
I have a Pacbrake on my 98. 5 24v w/5 spd. It worked fine with the accelerator microswitch for about 6 mos. Then it started all sorts of b. s. like not releasing sometimes, not coming on sometimes, not working at all sometimes. I called Pacbrake and they sent a new(at no charge) controller to replace the micrositch. It is wired to the ECM on pin #20 and works much better. Always the underhood part worked fine it was the actuator that was the pits. They told me I would have to get the ECM reflashed at Cummins or DC to turn on pin #20 but it was already turned on when I tried it after installing the wiring.
You will like the brake for towing. It is a great safety feature as well as easier on the brakes. I use it all the time, even when not towing,(except when wife is along-she hates it) as it makes a neat sound and still provides the same advantages.
Make sure you get the ECM controlled set up, not the accel. pedal microswitch.
1998. 5; 24v,3500,4x4,SLT,QC,5 spd,3. 54LS, 4 whl. antilock, all options available when ordered, 18k lb. Reese full tilt 5th whl. hitch, oem full length diamond plate running boards, eyebrows & hood dam, bed edges,bedhooks plus Rhinohide liner, Pacbrake, britebox,"deepdish"mats, matching topper shell, Sandstone(looks gray to me) & camel leather, stainless fender eyebrows, chrome(and road tar) exhaust turndown pipe.
brush guard, SPA digital boost/egt gauge and pillar mount.
Lowered rear end 4" to set truck level.
See My Truck
1980, W200, regular 4 door crewcab, 360 gas, auto, 68k original miles, 4 coats of Zeebart but losing ground to the saltwater anyway.
