Prodigy & E-brake
I have this combunation and I love it. I have the e-brake attached to pin 20 of the ECM. It is completely independent of the trailer brakes. This allows me to disengage the cruise when going downgrade and holding speed in check without generating heat and wear in the trailer brakes. This normally works great. If, however, the grade is steep, I will use the brake pedal to release the cruise and not let up on the pedal. Since the Prodigy works by sensing the angle of decelleration on an inertia sensor,determing the angle at the instant the brake lights come on as no braking yet, it applies the trailer brakes proportionally to the total decelleration forces acting on the truck. This thereby incorporates the e-brake force in the calculation for the trailer brakes. This mode also works great and saves on both sets of brakes. I can't therefore see any reason to connect the e-brake to the brake lights, as that would allow unnecessary trailer brake wear.
I AM thinking about making a switchable connection for when I am NOT towing, since I use the e-brake a lot when slowing down. I currently have to remember to touch the foot brake lightly to turn on the brake lights.
