Engine/Transmission (1998.5 - 2002) Exhaust Brake
2nd Gen Non-Engine/Transmission I Have Had It! I Think
Just wondering if an exhaust brake will fit a 4" exhaust flange? Im assuming it will, because the bolts on the downpipe match up with the back of the turbine housing. BUT, if I put an "e-brake" :-laf in, will I have to shorten up the down pipe? Thanks for the help!
If you are talking where the pipe bolts on the exhaust elbow with the 2 bolts, no, you won't have to shorten the pipe, the exhaust brake replaces the elbow. At least most of them do, I have a Jacobs, easy install. :D
Tom
2001. 5 2500 4X4 5-Spd LB QC Black. DD TTPM, DD Stage-1's, Catcher ECM, AFE, Bully Dog 4" pipe, JAKE Brake w/shifter switch, Geno's Banjo's, 3 Autometer's on the A-Pillar, Gear Vendor's O/D, Firestone Air Bags, Redline Oil thoroughout. :D
Depends on the Brake. Banks is different and comes with a new down pipe. Available in 3. 5 or full 4" outlet and down pipe. The rest of the turbo mounted brakes just replace the current elbows. SNOKING
