Exhaust Brake?
Jake brake install???
camshaft performance code
I have a 5. 9 cummins in a 06 ram 2500 and I use to have the jake brake installed when I had the stock turbo but then I upgraded the turbo to a HTB2 64/13 from High Tech Turbos and the jake brake would not fit. It hits the firewall. And also the air pump the opens and closes the valve on the brake is in the way for the 1/2 inch vulcan big line kit to go into the CP3 injection pump. My question is if anyone knows a exhaust brake the will fit with the turbo that I have now? An exhaust brake that dosent interfere with anything else already on the truck? Thanks.
Try the BD brake that mounts just after the down pipe. With this you can use any type or combination of turbos. I have this break and am happy with it after I changed out the air hose with some industrial standard 1/4" hosing.
Good Luck.
Do you want to sell the Jake brake? email me if you do. hnryfam#sandpoint.net
I put the in-line pac brake in when I did the twins. It works with a compressor instead of a vacuum pump. I was able to keep all of the Jake elecronics and I just spliced the vacuum selinoid wires to the pac seliniod. I was able to use my air bag compressor so I didn't even have to by one.
PM Jelag for more info on the PAC.
Aaron
