If your engine is factory stock you have no reason to be concerned. If your engine is modified you should be more worried about melting a piston than damaging the turbocharger.
The previous ISB5. 9 in the HO version from 2004. 5 through 2007 was designed to run indefinitely at 1425-1450* egt. I have not seen figures in writing but believe it is safe to assume the ISB6. 7 is also safe at those temps. That's egt measured preturbo in the exhaust manifold.
