Currently with the 14 cm housing I am getting around 35 lbs of boost, but EGTs are a tad high, and require a bit of monitoring, which I know is expected with the 14. I still have plenty of turns to go on the full fuel screw, but I don't want to add any more fuel at my current EGT levels. So here is my question: Should I change to the 16 cm housing? I know this will lower boost levels, but it will also lower EGTs. Can I make up for the lost boost with the fuel screw???? If I had a 16cm laying around I would just give it a shot, but before I lay out any cash I'd like some opinions. Been mullling this over in my head for awhile, and thought I's see what you guys think. My opinion is that I may be able to compensate for the lost boost of the larger housing with more fuel, which will bring some of the boost back, but I don't really believe that I will be able to gain anything over where I am now. Or maybe I'm going down the wrong road here?
TIA
AJ
TIA
AJ
