CVR222NV
I took my truck to a friend who is a diesel mechanic to have him check a few things on the truck and as he was inspecting the motor pointed out I had exhaust leaks at #1 and #6. The leak at #6 is starting to compromise the short rubber hose on what appears to be a cooler line that goes into the firewall. Looks like the gasket is blowing out. My buddy cautioned that when I pull off the manifold it might be warped and require replacement and should therefore consider an aftermarket exhaust manifold for better performance. Geno's has Mopar, OEM Cummins and BD as options and some research disclosed another option made by AFE. No matter what I will add a stud kit and change the hoses. Do I have any other options? Any other suggestions or recommendations? TIA
