Howdy,
I am relatively new to turbo diesel Dodges and TDR. About a month ago I purchased a '95 2500 4x4 with 145K on the clock and engine in near stock tune - plate all the way forward and line to the turbo wastegate disconnected. That last bit troubles me a tad, but haven't had time to research it on the forums. I suspect AFC star wheel is in OEM position - no black smoke ever. Bought the truck with light bubble rust over the rear fenders and a few minor (hopefully) problems to keep the initial price of membership down to $6. 2K. Been quietly lurking around the forums since then, trying to pick up some general knowledge by osmosis.
My inaugural question on the forum relates to the exhaust.
The current set up is a home brewed 1/8" walled 4" straight pipe attached to the stock downpipe about where I gather the cat would have been (had no idea these things had a cat). The guy had good intent, but welding that heavy tube to the frame in two places was not a very well informed move. I learned not to do that when I was a kid. The entire box functions as a speaker diaphragm. Sometimes the entire truck gets into the act. Can't wait to get it replaced.
To that end, I bought a s/s Rip Rook 4" turbo back w/27" muffler after perusing the forums for recommendations. Haven't got it yet, but I'm scoping out the install. Looking at the bolts holding the down pipe clamp at the cast turbo exhaust elbow, I'd say there is about 0% chance they are going to back out of their holes. In the spirit of planning ahead I'd like to hear other folks experience with this.
The way I see it, after I spend a bunch of time trying to sweet talk them out with the torch, penetrating oil, vocabulary, etc. , I will finally snap them off. I can then either drill and retap the holes to the correct thread (which is difficult to discern right now), or I can drill them clearance for the correct bolt diameter and run the bolts right through the flange into nuts and lock washers and not have to worry about it again. I'd appreciate some informed input on this. There is not a lot of material on those flange ears and I hate to weaken them with thru holes, but if you've tried tapping heat cured iron it has the potential to be a real gut wrencher. I don't need a broken tap in one of those holes right now.
A complicating factor is that my shop was struck by lightning and burned badly in July. I'd say I'm about 1/4 of the way to recovering from that, cleanup wise, never mind rebuilding things like work benches and shelves. For instance, before I use my torches I will have to clean a thick film of greasy black goo off them and hope I can clean the gauges well enough to read them. Same applies to all my tools. Not sure where my stud remover is. No compressor to run my now rusty air hammer, a really useful tool if applied with some thought. Don't know where my anti-seize is.
Don't have a fire. It has ruled my life this entire summer, and will continue to do so. For the same reason, my responses to this forum may not always appear timely. Sorry in advance.
Any comments appreciated.
Regards, Chuck
Regards, Chuck
