I've been hearing it ever since I joined TDR. It is basically an old wive's tale. It is based on the claim that aluminum will begin melting at 1300* and the pistons are aluminum so they'll melt. I'm telling you, that simply is not true.
The top of the piston probably "sees" 1300* but only instantaneously at time of combustion in a running engine. The piston is surrounded by a cooling water jacket and has engine oil squirted on the underside, also for cooling.
My '01 had RV275hp injectors installed when it had 6 or 8k miles on it and still has them in it today with about 365k to 370k on the same engine, never overhauled. It would easily cause egt to hit 1600* with a quick flooring of the throttle pedal on a grade.
I have posted many times in the past - I am fully aware that knowledgeable people like my friend Bill Stockard, Joe Donnelly, and others advise against it but for 325,000 miles that I owned that '01 I put my foot to the floor on long steep grades with trailers on and let it pull in sixth gear with the egt at 1300 to 1325*. I never backed out of it unless egt continued to rise or the engine couldn't hold 1600 rpm. If the tach continued dropping I backed out of the throttle and downshifted to fifth. Many times the pyro pegged at 1600* for a second or two before I backed out of it and held it at 1300*.
I know that working it that hard probably causes added wear and may cause premature failures, dropped valve seats, dropped valve heads, cracked upper rings, or worse but that never happened. That old engine still runs great today after the treatment I gave it.
The 2004. 5 and later which are the same basic design and using similar pistons, valves, cylinder heads, etc. were designed to operate long term at 1425* under full power, full load conditions. They use valves etc. designed to tolerate the higher combustion temperatures.
The engines are a lot tougher than many think they are.
