IF YOU ARE RUNNING EXTRA FUELING, IT MIGHT BE A GOOD IDEA TO GET RID OF THE CAT IF REGULATIONS ALLOW IN YOUR AREA OR YOU WILL BE REPLACING IT ANYWAY, THE CAT WILL RUN ALOT HOTTER THAN NORMAL AND EVENTUALLY MELT DOWN AND LEAVE YOU STRANDED, MBRP IS A GOOD PRODUCT FOR THE MONEY, IF YOU WANT TO SAVE SOME MONEY, YOU ALREADY HAVE 4 INCH EXHAUST, DELETE THE CAT AND MUFFLER AND PUT A TIP ON THE TAIL PIPE, IF YOU WANT QUIET, GO WITH A STRAIGHT THROUGH DESIGN MUFFLER, IF THE TRUCK RUNS STOCK FUELING, DELETING THE MUFFLER ONLY WOULD WORK TOO, ITS ALL ABOUT WHAT YOU WANT... .What would you guys recommend. 2004. 5 5. 9L Auto 4x4. I want to delete the cat and maybe the muffler or just a straight through design, maybe MBRP?
