Exhaust ?
what dos "Err" mean ?
New truck ordered
I have read most the post on exhaust systems and had some question.
Is there any performance or mpg advantage to take the resonator and muffler off a totally stock engine?
Is it just for sound effect?
Thanks
2001. 5 2500 Q\C,lwb, white/w gray int. ,HO,6-spd. ,3. 54,trailer tow, camper special,custom bolt-in G/N,Pryo/Boost,
See'ya down the road Michael
Rusty - I just pulled the muffler off of my truck. . and to be honest will you I only gained two things. #1 my turbo seems to spool up faster and #2... when standing out side of the truck, the Exhaust has a deeper pitch to it. No MPG advantage at all. Which is fine with me... the sound makes up for it. LOL
Kev
[This message has been edited by K_Arts (edited 12-18-2000). ]
Rusty,
I agree with Kevin. Additionally, your exhaust temps will go down 100-150 degrees at full pull, which is no big deal unless you are Bombed. Also, it sounds real nice, not too loud. Leave the resonator in.
I personally think replacing it with 4" straight exhaust is a waste of money unless you like it real loud or are at nuclear bombing levels.
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar. VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (Geno's Muffler Eliminator). Re-routed breather stink tube, 2WD-low kit, SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
78,000 miles (11/17/00)
[This message has been edited by Sean Flanagan (edited 12-18-2000). ]
I saw no evidence of lower EGT's with the straight 3" pipe on my truck. I can get it to 1k degrees pretty quickly, but can not get it over that. My truck is stock except for a K&N filter and the straight pipe. I think that temperature is normal for an unloaded stock truck at full throttle.
2000 RAM 4x4 2500HD Reg cab. Properly valved 5. 9 Cummins. 5 spd. 4. 10 LSD. Stock except for K&N Air Filter.
After about three months of having the truck straight-piped, (no muff. no res. ). I returned to the muffler shop yesterday to have the resonator put back in. It's getting alot colder in my neck of the woods, and i'm idling alot more. Believe you me, the noise is substantial with only a straight-pipe. With the resonator put back in place it's much quieter, but still "throaty". When starting on a cold morning and letting it idle to warm up, I would hear comments from the neighbors, such as, "wow a 747 is taxing for take-off in the street. " So my advice, LEAVE THE RESONATOR IN-PLACE.
I agree with the "747" sound, but I am keeping my straight pipe, as I have coated the entire exhaust with Rustoleum High Temp paint. I also have found the combo straight pipe and Pacbrake exhaust brake effective at silencing those punks who crank their license-plate rattling stereos at stoplights.
99 Ram 2500HD 4X4 Quad Cab SLT Laramie, LWB, 5 Spd, 4. 10 LSD w/Mag-Hytech, Tow & Camper Pkg's, Forest Green, Fog & Clearance Lamps, 3" Stainless steel straight-pipe, PacBrake, Interceptor Bug Shield, Vent-visors, Westin Nerf Bars, Extang Tonneau, Herculiner Bed, Silencer Ring removed.
the straight pipes aren't bad for those little people at the stoplights with the cell phones either... #ad
2001 3/4 ton driftwood 24 valve HO 6 speed; straight piped
Jason
Rusty,
The advantage to a point is lower EGT's. You are able to move the exhaust gases out of the engine quicker resulting in lower EGT's. Now that is if you are not bombed. Bombed you add more fuel+air=heat. I went with a 4" exhaust with a muffler and noticed 150-200 degree drop in my EGT's untill I started bombing, then they went back up.
Jason you are bad, picking on those unsuspecting people at the stop lights, go to your room #ad
OK so if I just want a better sound and possibly better fuel mileage I could get a muffler eliminator kit and leave the resonator in and it would mellow the sound out. Is this true I can see two things under there is one the muffler, and the other the resonator. I don't know alot about this as you can tell. I will listen to all. I plan on doing something this summer before vacation.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
Unless you are never satisfied like some of us. I went with the muff removal kit and was in a week later removing the resinator. Same with my injectors, got DDI's thinking "that'll be enough", now I am a heartbeat away from getting the big daddy 3's.
Moral of the story, do it right the first time, go big and get it over with, if not, youll nickel and dime yourself to death trying to achieve what you should have done to start with.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
Okie, I've had the eliminater pipe from Geno's on for about a month now. Can't really say anything about mileage because of a lot of variables, but it feels better to me and sounds better. It produces a slight rumble that is not overly loud... . I left the resonator in place. I'm hapy with it.
01 2500 Sport, QC, LWB, Auto, 4. 10, 4x4, Camper Pkg, Geno's muffler eliminator pipe, rest is stock for now
Okie,Sheets is right,go big and get it over with. I went with DD's4" turbo back with muffler,easy install. HP don't think so,Turbo spool up faster YES,EGT yes lower,Sounds GREAT. #ad
01,2500,2wd,Auto,3. 54,Med Bronze,Tan Leather,All Options,Mag-Hytec Diff cover,DD4",Westach combo, Line-X(BOMBED)Soooonnn
Neighbors? I have an agreement with my neighbors, they tolerate my dual 4" straight-thru exhaust pipes at 6:00A. M. when I leave for work, and in return I don't kill their cats that trespass in my yard. #ad
I'm running open pipes for the lower EGT's, the sound is just an "extra".
Tom M.
Secretary of the Great Lakes Turbo Diesel Registry GLTDR B. A. D. Boys www.lubedealers.com/meers.html
[This message has been edited by Briar Hopper (edited 01-13-2001). ]
I removed my muffler with genos M/E kit a week ago and I am very pleased. Noticed a 50 RPM increase at idle and smoother at idle. Deffinatly quicker throttle response at low end not to mention the great sound along with the 5" monster tip I installed at the same time. Installation was easy thanks to Geno's. .
Forest Green Y2K 3500 QC, SLT,ISB,Everything but leather 4X4,or should I say 6X6, Auto, 410 LSD Michelin 235/85/16 M/S,Camper and Trailer Pkg. Silencer ring in glove box. Tow mirrors,Century color match high rise cap, Dually flaps w/Alum. diamond plate,Vent Shade three piece bug deflector,Bumper poles w/marker & turn signal lights,Stirrup steps,Lund sun visor. K&N Filtercharger. Muffler gone,c/o Geno's M/E kit. Ram receiver,Cup Smoothie,5" Monster Tip.
Y2K Red Durango,(for the wife).
97 33' Sunline Saturn super slide RV trailer.
Shake, Rattle & Roll!
