explorer script error every time??????
Database tuning - possible problems
Spell Check?
:confused: What gives. Every time I log on I ger internet explorer script error. Line 2 Character 3866 code o It's hard enough for me to navigate on here, what does this mean??? Someone know?? Tim I also get default setting down in the forum box!
You most likely have something on your machine blocking Javascript. Can you use the pull down menus at the top (right below the banner ad)? They use Javascript - I'm betting you can't. Check your anti-virus or internet security software and see if it's blocking Javascript. There should be a way to exempt the TDR from that. The other thing to try is to add www.turbodieselregister.com to your trusted sites list - see this thread in the website forum for information on that ]Having trouble staying logged on?.
You will get the default setting down in the forum style box unless you change it - everyone does. If you are changing it and it's not staying changed then your machine is not accepting cookies from the site - see the thread above for that too.
Moving this to the website forum.
