Exposed PDC Photos...
Where 2 get Good center caps
autometer pyro
What accessories have you added to the truck? I have seen several of your posts with quite a bit of additional wiring in the truck.
Accessories...
Additional: Superplug Oil Pan Drain Plug, Hallo Light, Hella Rear Fog Light, KC HiLites Rear Backup Lights with Manual Switch, BackOFF-MC Brake Light Signal Module Type II, Espar Heater with Timer Backlighting, PIAA 90 Pro Projection Fog/Driving Lights, Horton Fan Clutch, Mystique 2000 Immobiliser, ISSPRO Boost/Pyrometer Gauges, ISSPRO Turbo Temp Monitor, WeatherTech Wind & Rain Deflectors, Rancho RS9000 Shocks, Rancho RS5000 Steering Stabilizer, Fuller Transmission Oil Filter, Jacobs Exhaust Brake, Rhino HitchStep, Hidden Hitch Front Receiver Hitch, Webasto Sunroof, BRITE LITES Hi-Capacity Headlight Harness, HID Headlights, ATP Wrap, Bedrug Soft Bedliner, Multi-Battery Isolator, Sparelock, BD 2-Low Kit, Practical Solutions Boost Module, Molded Side Step, Line-X Spray-on Truck Bedliner, Mag-Hytec Front and Rear Differential Covers, Flip Pac Convertible Shell/Camper with Creation Side Windows, Pop & Lock Power Tailgate Lock, Wheel Locks, Mopar Spare Tire Lock, Hella DuraLED LT Brake, Signal, and Running Lamps, Seperate Red Brake/Amber Turn Signals, FourHella DuraLED Amber Side Marker Lamps, SS Ladder Bars, Second Spare Tire, Oilguard Bypass Oil Filter, Banjo Bolts, Schrader Test Ports, Nordskog Digital Fuel Pressure Gauge and Sending Unit, MileMarker Winch with Master-Pull Winch Rope, VMAC Air Dryer.
Waiting: ATS 3-Piece Exhaust Manifold, Walker Airsep, VMAC Underhood Air Compressor, Rickson's 19. 5" Aluminum Wheels, ARB Airlockers (Front and Rear).
Special: Jacobs Exhaust Brake Activation of Horton Fan Clutch (Switch Selective), Hella DuraLED LT Brake Lamps, and BackOFF-MC Brake Light Signal Module (Both Automatic).
Did you forget to mention the 4bt Cummins powered generator you have to carry around in the bed to power all of that?:D
Now I see why there are so many additional wires.
What brand of HID's did you go with? Where did you purchase them?
OK now with my job title here in BOSTON on the BIGDIG as a safety supt. I would have to ask just one thing after reading ALL of your additions.
DO YOU HAVE A FIRE EXTINGUISHER ON BOARD??? :-laf
DO YOU HAVE A PIC. ???
Fire Extinguisher...
Yes and it's HALON! Will post when I put it back. Carpeting is wet from last rain storm.
Jc--did I read that you have seperate rear amber turn singles incorporated in the lights? Do you have pics or part numbers on those?
Rear Amber Turn Signal's...
Wire rear stop/tail/turn signal's to be stop/tail and amber turn signal's. Factory backup light's were rewired for amber turn signal's. Work's GREAT! Wiring was run from steering column back. Added fog backup lamp's under bumper.
How did you convert the brake/park to leds? I can't seem to find anything that would seemingly work on that Hella site. Thx--Steve
LED's...
How did you convert the brake/park to LED's? I can't seem to find anything that would seemingly work on that Hella site. Thx--Steve
No conversion. Added Hella Australia DuraLED lamp module's to tailgate. I've tried LED bulb's but returned them because the flasher's wouldn't work correctly. Also cause problem's with other light's.
