extended idle
HOLY FLYIN' 1 TON BATMAN
HELP! Clutch install tomorrow and I don't have a pilot tool
I'm looking for an idle-up servo or another way to idle a 2001 Ram for extended time without combustion temps dropping. Does anyone use their exhaust brake this way? How long can the exhaust brake be left on? I wish the PTO input would raise the idle when activated like the GM, oh well. Any thoughts would be appreciated. Thanks.
93 W250 5spd Getrag, 16cm2 housing, Bank exhaust, K&N air filter, pyro and boost gauges and moderate pump adjustments. Daily driver and love towing anything.
I do leave the truck running with the exhaust brake one sometimes as long as 1/2 hour to 45 minutes. The exhaust temps never go over 450deg on my truck,and never had a problem so far.
If you look over at the 'products' forum,you'll see Practical Solutions has developed a high idle kit for our 24v Rams.
-Mike
'00 2500QC,4x4,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's,Midland cb,Clarion 6-disc changer
[This message has been edited by MikeR (edited 02-23-2001). ]
I use an electronic idle control. In 20 degree temps it keeps the eng water temp about 150 degrees at 1125 RPM. I've used it for up to 12 hours at a time. Lab test shows no fuel in oil. I don't use my jake brake for this purpose. Jake is on push button switch on gear shift, and button has to be held to operate. Tell tail is that there is no cloud of carbon or unburned fuel when I take off now.
Denny
'99 2500 4X4 White short Q cab to much added to put here
I use my exhaust brake for warm up and sometimes extended idle times as well. My pre-turbo EGT's stabilize at 600 degrees and I've had it idling for up to an hour with no overheating problems in 90 degree heat.
-Steve St. Laurent - President of the Great Lakes TDR
'98 QC LB (CMNSPWR), 4x4, ISB, 5sp, 4. 10 LSD, TST Powermax, 275hp RV injectors, Joe Donnelly modifed Sachs Clutch, custom ladder bars, SW fuel pressure gauge, BD exhaust brake, Isspro turbo temp monitor, front Draw-Tite receiver, rear Draw-Tite class V receiver, BFG 285/75R16 AT KO's, (all the common stuff clipped)
Before I had my e-brake, I built a idle control that really worked well when warming her up. I just adjusted the idle to around 1200 rpm's and after several minutes the temp. was up and I had heat. Now I use the e-brake. I used it tonight at work (unable to plug in), the outside temp. was 20F and the truck was sitting for 9 Hours. After 10 mins. of idle with the brake on, my water temp. was up to 170 and I had plenty of heat in the cab. Here's a pic. of my "caveman idle control". Hope this helps !!!
Scott W.
I use my Pacbrake for warm up and as long as 5hrs. while sleeping, egt. 400* and water temp. 190*. Cummins and Pacbrake both told me this ok. I have Practical Solutions High Idler, and it along with the Pacbrake, has cut down warm up time from 10min. to 5min. at 20* temp.
Larry
Y2K 3500 QC,SLT,4X2,White, 6spd,3. 54 lsd,Banks Stinger +,Pacbrake,Pilar mt. EGT & Boost,Amsoil air filter,all amsoil lube w/BMK-15 filter system,MagTec rear cover,putco boss rbs. w/ rear ext. &flaps,20K reese,100 gal. aux. fuel,fold up T cover,5K airlift bags w/comp. ,ranger 2950 cb pushing palomar 225 amp,phantom radar det.
I like the fancy solutions and will eventually get one. For now I have a 6 dollar gadget I found at a truck stop. It hooks to the dashboard and pushes on the go pedal with a very simple adjustable setting.
This is easier to operate than vice grips.
